Hi All,
The fuel tank on my M37 isnt in too horrible shape, but has more gunk, rust, sediment in the bottom than I am wanting to stay. I have had good luck with Bill Hirsch tank sealer but need to clean it out first. I could clean out the center section fine, but the areas on the other side of the baffles are out of reach. The gas tank on my 57 W-100 was so gunked up I cut a large section out of the top to get access. I would rather not do that to this tank. I am not going to send it out to Gas tank renu.
I am interested in other ideas on how you have cleaned out your tanks.
Here is my current thought. Build a clamping fixture to attach the tank to the end of my cement mixer, held skewed to the end of the mixer to provide an oscilating action. Then put a couple of quarts of gravel in it and let it spin for a couple of days. Any thoughts?
Tim
Gas tank cleaning
And wear ear plugs...
Actually some people have used electrollisis (sp?) to clean gas tanks. If you do a web search you will find some information. I know the M715zone.com had a discussion about that about a year ago.
The other thing you might consider is seeing if your local radiator repair shop will tank it for you. Many small shops will do that an only charge you a few dollars to have it done. Just another option.
- CPL
Plastic tarp & a few giant spring clothespin clamps work well on Chevy Blazer, Ford Exploder and most hatchbacks. Same tarp and clamps work pretty well on most car doors too. I use the convenient glass cubes in a concrete mixer for a lot of things.Josh wrote:good idea Franz. It's also inert, if you happen to forget a few pieces in there. Id wrap a few plates up in a heet, then bust them... would be easier then trying to pick it up off the ground broken.
I worked in a body shop, those little chards are sharp!
Add walnut shells or ground corncob if you want a nicer finish and less noise. I don't recommend them in tanks though.
