Heater arrived yesterday.......
Nickathome
Post by Nickathome »
My cab heater arrived yesterday. So now between the wiper motors, and the heater, I have a couple nice projects to get me through the winter. Will be installing the wipers next week while off for Xmas holiday. Bought all wiring yesterday. Heater is going to have to wait until I can round up all parts.
Anyone got a photo of a Jeep heater mounted under passanger dash? Will need to fab a bracket to mount it and need ideas, thanks.
NCmountainman
Post by NCmountainman »
Nick, on olive-drab.com, a guy by the name of Harris Neil posted a very good write up on installing the M-151 series heater in the M37. I'll try to post a link to the article.
http://www.olive-drab.com/od_m37_php3
Sounds fairly simple!
Ed Bennett
MVPA #31853
1951 Dodge M37 G741
1983 Jeep CJ5
1942 Chev G506 (SOLD)
Nothing is Fool Proof to a suffeciently talented fool.
Nickathome
Heater.
Thanks. I have a copy of that write-up. Others may be able to use it though.
Cabell Garbee has a good write-up, with pix, on a 151 heater he installed in his M37 at: http://www.garbee.net/~cabell/heater.htm
DaveO
Post by DaveO »
Nick,
I posted some off-site. Click the picture to take you to the album. It's as close as I'm able to come to posting here. Apparently, I'm technically deficient. Each picture has some comments.
I'm horrible at photo-documenting my work. I can have more pictures in a couple of days if you want them.
Good luck and clear windshields...
Dave
Dave Ostlund
1941 WC9
1952 M37 W/W
1953 M38A1
M116
RTFB
Nickathome
Heater install
DaveO;
Thanks for the photos. Thats exactly what I need to use for my install. I hope you don't mind, but I saved the link to your photos so I can use them as a reference. It showed me exactly which valves, etc I'll need and where to place the hoses. I didn't think my truck's engine had the plugs in the places everybody has mentioned(I have a 230 industrial engine in my truck), however it appears that I do. Thanks again for the photos.
DaveO
Post by DaveO »
Nick,
Happy to help.
One other thing I forgot to mention was that I mounted the slow speed resistor on the top of the steering column brace. That keeps it from touching anything under the dash (like wiring) in case it gets hot, and I don't kick it while my feet are flailing around with the pedals.
Have fun...
Dave
Dave Ostlund
1941 WC9
1952 M37 W/W
1953 M38A1
M116
RTFB
Good Job!
DaveO wrote:Nick,
Dave
Hey Dave, I think you did a fine job.....but I gotta ask, what is going on under your carby, is that a fuel filter or another fuel gizmo?
Nickathome
Heater parts
Dave, where did you get the resistor and toggle switch? I can get all other parts at NAP, but don't know where to get those two.
DaveO
Post by DaveO »
Thanks Bruce. I'm pretty happy with the way it turned out. It's nice to keep the glass clear in the winter.
It's a Racor filter/ water separator. It came with the truck, and I kept it when I cleaned up the rest of the disaster that was the fuel system (that picture is old). It's meant for diesel, but does a fair job of pulling the water from gasoline. There is a filter in the top of the unit, and a big bowl (about a quart) to settle the water out. It's mounted to the splash shield, and is not really in the way of anything. They've discontinued this model, but the filters are still plentiful.
Nick, when I bought my heater kit all the electrical stuff was in there. Saturn has the three position, center-off switches:
http://www.saturnsurplus.com/electrical/switches.htm
About midway down the page. Obviously you don't want the momentary type. I'm not sure of the resistor. I'm on the other side of the country from my truck so I can't really get a resistance value. Maybe some kind soul here can put a meter on one for us, or know of a source for the original resistors. Saturn could well have them.
Dave
Dave Ostlund
1941 WC9
1952 M37 W/W
1953 M38A1
M116
RTFB
Nickathome
Switches
Dave;
Thanks for link. I will order one from Saturn.
I think I should have probably bought the whole kit vs just the heater, oh well, water under the bridge. I know with the kit some parts would not get used though. One item I see that I will definitely need is that baffle that has the one big opening and the two smaller ones, that fits over the end of the blower motor. Anyone know where I can obtain just the baffle?
There was a time when Sam Winer had the entire kit for 85-89 bucks, plus s & h, to me on the right coast it was $115.00, everything was in it too.
Not sure what this fits, is this the kind you need? If it is it's yours for 0$ if you want it.
DaveO
Post by DaveO »
Can't beat that price! That sure looks like the right one. I plugged one of the two holes. The other runs up to the winshield distributor/manifold/whatever. The door with the orange gasket opens into the cab. Good for the passenger's toes, but by the time it gets over to the driver's side, I'm already getting heat off the engine and windshield.
Bruce, here's another shot of the Racor:
Ha! Finally got this picture posting thing licked...
Dave Ostlund
1941 WC9
1952 M37 W/W
1953 M38A1
M116
RTFB
NCmountainman
Dave, what is the device in the line going into the filter? Is it a pressure regulator? I think that I am going to need a pressure regulator if I can't find a low pressure 24v fuel pump. Are you running an electric fuel pump? If so, can you tell me the make and model.
Ed Bennett
MVPA #31853
1951 Dodge M37 G741
1983 Jeep CJ5
