Assessment:
Idles good, but doesn't handle hills under load too well;
Noisy (and I knew it would be) but sounded like an old war horse should;
Oil pressure and temperature gauges show good PSI and about 170 degrees for the coolant;
Shifts OK and I hit all 4 gears with no unusual chatter;
Hard starting at the gas station after fill up-seems to be running rich;
Several smiles and waves like I just arrived off the 38th Parallel-priceless!
Questions:
Timing appears to be off. When I attempted to set it, I don't get consistent fire from the #1 plug wire. When I move the pick-up probe to other wires, it lights just fine. The cap, rotor, plugs and wires are all new, along with the coil, and the engine isn't "missing". The timing light is also new. Any idea what might cause this?
Fuel mixture seems rich-I suspect I can lean it out once I have the timing set at 4 degrees before TDC. Anything else I might need to look at before I stretch it on a longer trip?
Any guidance or advice would be greatly appreciated!
