I can't find any pics or diagrams of the battery box and what's in there (besides the batteries). I see all the holes but I'm trying to figure out their function. Does anybody have any pics of what's the setup looks like without the batteries installed. Mine had particle board in the bottom, you can imagine what that looked like after years. I don't see a break down in the parts manual.
John
Battery Box setup
- sturmtyger380
Re: Battery Box setup
I was looking for photos I might have. Seems I didn't take any of the bottom of the box.
The box has holes it in to allow it to be bolted to the body. Other than that there are holes to bolt the battery tray to the box. Can't remember the holes might be for both.
Tray: https://www.worthpoint.com/worthopedia/ ... 3789848894
There is one other hole that is a drain from the tray. That's the small hole between the two mounting holes in the picture.
Other than that there is the hold down frame and the long carriage type bolts that come up from the battery tray.
https://shop.midwestmilitary.com/produc ... ld-down-3/
Then on the side of the box where the cables come in there is a rubber holder with a metal shell.
https://shop.midwestmilitary.com/produc ... ainer-kit/
Hope this helps.
Hope this helps.
Thanks for the pic. I'm missing the tray and couldn't find a picture of it. This answers my question of the holes and what they're for.
John
John
@johnpstoll I have the tray and the battery hold down, I sold my M37 so make me an offer. Below is link to my for sale add here.
http://www.g741.org/PHPBB/viewtopic.php ... 74fb6c0571
This is the builder’s blog section. You should have put this question in the technical sub-forum.
Sebastian
(Moved to the Technical group per Sebastian's suggestion).
Here are two pictures of just the battery box - without the separate battery tray (that the batteries sit in), without the top hinged lid, and without the rubber grommet assemblies where the battery cables go through the box.
This battery box sits on the floor of the cab under the passenger seat.
Then the separate battery tray (that the batteries actually sit in) goes in the bottom of the battery box.
Then four bolts go through the holes in the battery tray, then through the holes in the bottom of the battery box, then through the holes in the cab floor and into four welded nuts on the bottom of the cab floor.
That lash-up holds the battery tray and battery box to the cab floor under the passenger seat.
Then you put the two batteries inside the assembly.
Then there's a separate top hinged cover that goes on the battery box.
There's also two battery hold-down bolts that go from the sides of the battery tray to the battery hold-down to secure the batteries in place to the battery tray.
Battery box picture only attached.
Note two hinge pins where the battery box top attaches to and rotates open on.
Also note holes where the rubber grommets attach where the battery cables go through the box.
- Battery pix 1.pdf
- (244.3 KiB) Downloaded 154 times
Second picture of just the battery box (different angle).
- Battery pix 2.pdf
- (229.39 KiB) Downloaded 163 times
