Removal of front propeller shaft
investig8
Post by investig8 »
Hi Guys,
Is there any reason why I can't run the truck without the front drive shaft? I don't believe there is but just in case I thought I'd go to the experts...
Dennis
Investig8
1953 M-37
1952 M-38
greeno
Re: Removal of front propeller shaft
Post by greeno »
Well…your 4wd won’t work!
I had a Silverado with a bent front driveshaft. I used to take it off in the spring and put it on in the winter.
Not really an answer but I’m curious too.
M37
YEAR: 1954
Murf
Post by Murf »
It will probably drive and steer slightly smoother. It won't hurt a thing.
