tool box floor questions
DSC01576 (Small).JPG (88.9 KiB) Viewed 2143 times
DSC01575 (Small).JPG (87.34 KiB) Viewed 2143 times
DSC01574 (Small).JPG (93.09 KiB) Viewed 2143 times
I am putting the tool box floor on, and have run into a "thing". looking at the pics, you can see that the center section is about 3/16" lower (pics are of it upside down) than the outer portions. When I took this apart, the floor was totally rusted out- I found a replacement. All this happened years ago so I do not remember if there was something there to take up the gap. Anyone know?
greeno
Re: tool box floor questions
Post by greeno »
Looks about right. When you add the strip caulk and tighten down the bolts there will be no issue.
M37
YEAR: 1954
greeno
Post by greeno »
Tough to see but my tabs were offset too.
M37
YEAR: 1954
DSC01580 (Small).JPG (96.29 KiB) Viewed 2110 times
DSC01579 (Small).JPG (92.99 KiB) Viewed 2110 times
I found some 1"x1/8" bar stock laying around the shop, and made a couple of fillers. Painted them, seam sealed them and everything fit great.
greeno
Post by greeno »
Did you bolt the toolbox to the frame? I think you want them divorced for flexing.
M37
YEAR: 1954
DSC01581 (Small).JPG (104.79 KiB) Viewed 2094 times
greeno wrote:Did you bolt the toolbox to the frame? I think you want them divorced for flexing.
No, it just looks that way in the pic- attached to the crossmembers (for the bed)
greeno
Post by greeno »
Indeed! I'm getting old...
What paint color and brand are you using?
M37
YEAR: 1954
greeno wrote:Indeed! I'm getting old...
24087, I have bought 5 gallons of the stuff from the same vender on ebay, every time I get it it comes from a different paint co. The colors varied slightly from company to the next. So, I poured all of it into a 5 gallon bucket, mixed well and poured it back into the gallon paint can- now they are all the same color,
sturmtyger380
Post by sturmtyger380 »
That's what happened I am sure during WWII and probably after for Army vehicle colors. Everyone gets all hung up on what color is correct, while Ford was recycling used but not sprayed paint on their assembly line. Just dump it all together and spray for the next production run. Not to mention what happened in the motor pool once the truck / jeep was in the field.
vit16
Post by vit16 »
So beautiful peace of machinery!!
DSC00744 (Small).JPG (129.15 KiB) Viewed 2045 times
Just for fun, here is the "before" pic. had to replace the floor and both rails.
Mine was bad, but not that far gone!
