PARTS LIST INVENTORY REVISED
DaveH
Post by DaveH »
Here is a revised PARTS INVENTORY LIST...
SOLD is noted by the parts already purchased.
Thanks for looking.
Dave
Leicester, NY 14481
REVISED INVENTORY LIST
BOX 1 / PAGE 1
1. SET, GASKET ENGINE VALVE - 2 AVAILABLE - 2805-700-5408 SOLD
2. SEAL, BEARING RETAINER - 4 QTY- FOR FRONT AXEL OUTPUT SHAFT 5330-
141-2461 SOLD
3. SWITCH, STOPLIGHT ASSY. – 1 QTY - 5930-741-2642 SOLD
4. POINTS, DISTRIBUTOR - 2 QTY - NO FED STOCK NUMBER SOLD
5. PIN, STRAIGHT HEADED - 2 QTY - ORD PART NO. 594145 PAGE 179 SNLG-741
6. RETAINER -2 QTY- 2530-00-423-2746
7. WASHERS, SEALING CAP, DISTRIBUTOR, WATERPROOF ORD NO; 7374894
PAGE 80 OF G-741 -12 QTY-
8. SHIM .007 -5 QTY- 5330-00-734-9269 SOLD
9. FELT MECHANICAL -2 QTY- 5330-734-9109 WHITE FELT STRIPS
10. KIT, REPAIR, WINDSHIELD WIPER MOTOR -2 QTY- ORD NO. 5327347
11. ROTOR, IGNITION, DISTRIBUTOR ASSY. -2 QTY- ORD NO. 7348578 PAGE 79
OF G-741 SOLD
12. ELBOW ASSY. WITH SCREEN -1 QTY- NO NUMBERS
13. LIGHT, WATERPROOF, HEADLIGHT, HIGHBEAM INDICATOR ASSY. -1 QTY-
24 VOLT ‘GLASS’ PAGE 85 G-741
14. PARTS KIT, UNIVERSAL JOINT, WINCH DRIVE SHAFT -1 QTY -
ORD. NO. 7372674 PAGE 165 SNG-741
15. PARTS KIT, SERVICE BRAKES -1 QTY OF EACH PART-
CONTAINS; FLAT WASHERS
7373752 CAM ADJ., SHOE
7373753 PIN, ADJ., SHOE
7351239 SPRING, COMPRESS
7351265 SHOE GUIDE 7410464 PIN, ANCHORS
BOX 1 CONT. / PAGE 2
16. SPRING, SHOE GUIDE / OR CLIP SPRINT TEN. -4QTY- ORD NO. 7351265
PAGE 131 SNL-741
17. CONTACT SET, DISTRIBUTOR, ASSY. -1 QTY- NO ORD PART NO. SOLD
18. BRACKETS, THROTTLE CARB CONNECTORS -2 QTY- 2540-00-423-2698 SOLD
19. GASKET, DRIVE FLANGE (POSSIBLY) PAPER -10 QTY- 5330-00-292-4332 SOLD
20. FRONT AXEL, FLANGE BEARING GASKET, SHIMS -2 QTY- NO ORD PART NO. SOLD
21 GASKETS, DRIVE FLANGE -3 QTY- 2520-423-2580 ORD NO. 7351041
PAGE 125 SNLG-741 SOLD
22. SEAL, REAR WHEEL, PLAIN ENCLOSED -2 QTY- 5330-297-6438 SOLD
23. GASKET, VALVE COVER -2 QTY- 5330-362-3061 SOLD
24. MANIFOLD GASKET KIT -1 QTY- 5330-00-362-3068 SOLD
25. BUSHING, MOUNTING, EYE SHOCK ABSORBER, RUBBER -16 QTY-
PAGE 147 G-741 SOLD
26. KIT, REPAIR, GOVERNOR -1-QTY- 2990-737-8236 ORN NO. 7378236
PAGE 40 SNL G -741 SOLD
BOX 2
!. RUBBER, WEATHER SEAL, WINDOW GLASS TO INSIDE OF WINDSHIELD -4 QTY-
2. STEERING, KNUCKLE BEARING SET, FRONT AXEL -1 QTY- SOLD
2 UPPER CONES
2 LOWER CONES
4 CUPS
3, TIE ROD END, STEERING, LEFT ASSY -1 QTY- ORD NO. 7349051
FEDERAL STOCK NO. 2530-734-9051 PAGE 142 SNL G 741
4. OIL FILTER ELEMENT -1 QTY- 2940-00-141-9025
BOX 2 / CONT. PAGE 3
5. REBUILD KIT, WATER PUMP -1 QTY- 2930-21-102-4190
BOX 2 CONT. PAGE 3 SOLD
6. CUP, UNSURE OF PART USAGE, -4 QTY- 3110-00-100-1567
7. ARM, DOOR CHECK -2 QTY- 2510-734-6912 SOLD
8. PULLEY, FAN BELT -1 QTY- 3020-21-103-0726
9. UNIVERSAL JOINT, REPAIR KIT -1 QTY- DODGE PART NO. 94755
GROUP 0902 SOLD
10. TANK, GAS, FILLER CAP -1 QTY- NO PARTS NUMBER
11. SPRING, HELICAL, EXTENTION -1 QTY- ORD NO. 7351080
FED STOCK NO. 5340-205-4665 PAGE 138 SNL G 741
FOR MECHANICAL CONTROLS SOLD
12. SLEEVE, BUSHING -4 QTY- 3120-00-423-2719 CHRYSLER PARTS
13. PARTS KIT, HYDRAULIC BRAKE WHEEL CYLINDER -4 QTY-
2530-00-537-2210 WAGNER PARTS
14. GASKET -2 QTY- LARGE, PAPER 2520-00-692-6056
- 1 QTY- CHRYCO PARTS
15. GASKET SET, TRANSMISSION -1 QTY- CHRYCO PARTS
16. GASKET -1 QTY- LARGE, PAPER 5330-366-6424 MOPAR / CHRYSLER
17. GASKET, STRG FLNG OIL SEAL -2 QTY- G741-7348989 CC 924634
APRIL 1953
BOX 3
1, WHEEL STUDS, RIGHT HAND -4 QTY- SOLD
2. BOLTS, SPRING SHAKLE -2 QTY-
3. LATCH, HOOD SOLD
BOX 3 CONT., PAGE 4
4. OIL SEAL, FRONT AXEL -2 QTY- DODGE GROUP 1005 PART NO. 924432 SOLD
5, MASTER CYLINDER REBUILD KIT
BOX 3 CONT. PAGE 4
6. BOOT, GEAR SHIFT -1 QTY- SOLD
7. SERVICE BRAKE, REPAIR KIT -2 QTY- 2530-622-0073
8. KIT REPAIR, MASTER CYLINDER -1 QTY- 2530-00-620-3556
9. REMOVER, OIL SEAL -1 QTY- 5120-00-795-0120
10. BUSHING, IDLE ARM -1 QTY- SOLD
11. CYLINDER ASSY., HYDRAULIC BRAKE WHEEL, LEFT 2530-737-6401
PAGE 133 SNL G 741
12. OIL PRESSURE INDICATOR GAGE -1 QTY- 6620-056-9584
13. BRAKE PARTS, MISC. BAG
2 SPRINGS AND HARDWARE
4 BOLTS
4 FELT GASKETS
4 OIL SEALS AND HARDWARE BEST FOR ME TO SEND PHOTO
BOX 4
1. SPARK PLUGS, CHAMPION, WATERPROOF, COPPER PLUS -20 QTY- STOCK NO. 588 XMJ14 / MS35909-1 SOLD 6….2 MORE SETS OF 6 AVAILABLE. $80 SET
2 . OIL SEALS, NATIONAL, FERERAL-MOGUL -2 QTY- HUBS SOLD
3. OIL SEAL, NOS MILITARY, HUBS -1 QTY- SOLD
4. THERMOSTAT, FLOW CONTROL, WATER TEMPERATURE, ASSY.
-1 QTY- FED STOCK NO. 6620-00-741-8932 CHRYCO PARTS SOLD
5. DISTRIBUTOR CAP, -1 QTY- AL 63 ECHLIN NAPA PART SOLD
BOX 4 CONT., PAGE 5
6. DISTRIBUTOR CAP M37, NOS, -2 QTY- I-AU-1055 SOLD
7. MASTER CYLINDER REBUILD KIT, BENDIX, -1 QTY- 2964-22964
8. RADIATOR CAP, -1 QTY- 703-1419 BALKAMP NAPA SOLD
9. OIL FILTER ASSY, -1 QTY- C-134A FRAM
10. THERMOSTAT, -1 QTY- 155 NAPA SOLD
11. THERMOSTAT, -1 QTY- 55 NAPA
12. ROTOR, -1 QTY- AL 62 ECHLIN NAPA SOLD
13. CONDENSER, -1 QTY- AL 869 ECHLIN NAPA SOLD
14. CONTACT SET, -3 QTY- CS 725A ECHLIN NAPA SOLD
15. CAPACITOR, CONTACT POINT, -2 QTY- BA 4386-59-FS
FED STOCK NO. 5910-358-6842-G741H SOLD
16. HYDRAULIC BRAKE LINE, -2 QTY- BH-4900 RAYBESTOS
17. BELT, FAN -1 QTY- FED STOCK NO. 3030-00-529-1334 CHRYCO SOLD
INDIVIDUAL PARTS / LARGE STORAGE
1. ADAPTOR SET, METAL BOX, FED STOCK NO. 4910-348-7600
DWG NO. A7541281
ADAPTORS FOR; GENERATOR, REGULATOR, SPARK PLUGS, DISTRIBUTOR,
IGNITION SOLD
2. KIT, TOOL, CARBURATOR, 28 ADJUSTMENT TOOLS. SOLD
3. SUPPORT ASSY, EXHAUST HANGING BRACKETS, 5 QTY-,
FEDERAL STOCK NO. 2990-787-3684 SOLD
4. TIMING CHAIN COVER -1 QTY- SOLD
5. SHAFT, RIGHT, W/UNIVERSAL JOINT ASSY., SNL G 741 G741-73-747
TRACTA JOINT (IN ORIGINAL SHIPPING BOX) -1 QTY- SOLD
6. BRAKE, BACKING PLATES, -2 QTY- BLACK PAINTED SOLD
INDIVIDUAL PARTS / CONT., PAGE 6.
7. CABLE, SLAVE, 2 PIN, 20’ LENGTH, -1 QTY- EARLY VERSION FOR M37 M43 NOS
8. RACK, STORAGE, SMALL -2 QTY- 1095-00-115-4357 CAN SEND PHOTO.
POSSIBLY TO HOLD LITTERS?.
INDIVIDUAL PART / LARGE STORAGE
9. SUPPORT ASSY. OD PAINTED CHANNEL, UNKNOWN USE, CAN SEND PHOTOS
-1 QTY- FED STOCK NO. 2510-700-5406…..COULD BE 9406…HARD TO MAKE
OUT
10. HINGE, TAILGATE, OUTTER -1 QTY- FED STOCK NO. 5340-700-5439 SOLD
11. KIT, REBUILD, CARBURATOR, -1 QTY- SOLD
12. KIT REBUILD, WATER PUMP -1 QTY-
13. KIT, REBUILD, FUEL PUMP -1 QTY- SOLD
14. BRACKET, METAL, -2 QTY- FED STOCK NO. 2510-00-737-6829
15. CYLINDER, WHEEL, RIGHT SIDE -1 QTY-
16. HOSE, RADIATOR -1 QTY-
17. CABLE, BATTERY, TO STARTER ASSY. -1 QTY-
18. SHOES, BRAKE, -8 QTY- NOS, EXCELLENT CONDITION SOLD
19. PUMP, WATER, W-53 -1 QTY- NAPA PART
20. KIT, TURN SIGNAL, EARLY FLASHER BOX W/ALL HARDWARE, COLUMN
MOUNTED TURN SIGNAL, 600 SIGAIDE/ SIGNAL-STAT -1 QTY- SOLD
21. PUMP, FUEL, MILITARY NOS, FED STOCK NO. 291000-735-1345 -1QTY- SOLD
22. PUMP, FUEL, DODGE 50-56 W SERIES NAPA PART -1 QTY-
23. HUBS, NOS, M37 OR M42 -2 QTY- SOLD
24. CLUTCH ASSY, COMPLETE, -1 QTY-……SOLD
25. BRAKE, EMERGENCY, BAND, NOS, M37 OR M43 -2 QTY- SOLD
INDIVIDUAL PARTS / CONT. PAGE 7
26. ANTENNA BASE, CERAMIC INSULATOR -1 QTY- SOLD
27. HEATER, WHEEL, CAB -1 QTY- FED STOCK NO. 1005-00-153-1100
SQUIRREL CAGE
28. BRACKET, LIFTING, SHACKLE, REAL LEFT, CASTING, -1 QTY-
ORD NO. 8330146 CC NO. 1274771 PAGE 141 SNL G 741
29. BRACKETS, BOW, CARGO BED ASSY, -11 QTY- TAKE OFF PARTS SOLD
30. WINDOW, ROLL UP MECHANISM ASSY. -2 QTY- SOLD
31. LIGHT, MARKER, CANSITER -1 QTY- NO FRONT OR INSIDES… SOLD
32. CHANNEL ASSY, WINDOWS, -2 QTY- FED STOCK NO. 2510-737-4793 SOLD
33. STEERING KNUCKLE, CASTING -1 QTY- SOLD
34. DIFFERENTIAL CASTING -1 QTY- THE 3RD MEMBER SOLD
35. LINE, FUEL ASSY. -1 QTY- FED STOCK NO. 2910-495-0147
36. CURTAIN, CANVAS, REAR CARGO BED M-37, -1 QTY- SOLD
37. ARCTIC, CANVAS, GRILL RADIATOR COVER WITH HARDWARE -1 QTY-
38. POWER CONVERTER, OD METAL BOX, CABLES AND CLAMPS, PLUG
PLUG RECEPTICAL, ON OFF SWITCH, FUSE, 6 V DC, 12 V DC, 15 W 60W
ORANGE STAMP READS; SC3359A
40. TANK, FUEL, NOS….. SOLD
41. WIRING HARNESS, COMPLETE….. SOLD
***I TRIED TO EXPLAIN THE PARTS THE BEST I CAN. FEDERAL STOCK NO AND ORD NO’S SHOULD HELP OUT.
***FEEL FREE TO TEXT OR EMAIL FOR PHOTOS OF ANYTHING.
***dhasler16@gmail.com 585-991-8478
***PRICES AVAILABLE ON REQUEST. BUNDLE PRICING AVAILABLE.
***INTERNATION ORDERS ARE ACCEPTED HOWEVER BUYER MAKES ALL ARRANGEMENTS FOR SHIPPING.
***PAYPAL OR CHECKS ARE FINE. I USE ANOTHER EMAIL FOR PAYPAL!
texan396
Re: PARTS LIST INVENTORY REVISED
Post by texan396 »
Is item 10 in box 1 windshield wiper kit still available for sale ?
Is the kit for the standard Trico issued wiper motor ?
Thank you
