Rear Hub Sleeve
sturmtyger380
Rear Hub Sleeve
Post by sturmtyger380 »
I found this old post that mentions the part number for a sleeve for the rear inner spindle seal. Rear Spindle 99281.
http://www.g741.org/PHPBB/viewtopic.php ... lit=sleeve
What about a sleeve number for the outer surface area where the outer seal rides, anyone have that? Or would that interfere with the bearings slipping onto the spindle?
Tom P
Re: Rear Hub Sleeve
Post by Tom P »
That seal rides on the outer bearing lock nut, if I'm understanding you.
Don't know of the sleeve number I just replaced the nut from any of the usual suppliers when needed.
I know John at MW had some made.
Tom
"47" WDX WW
"52" M37 WW
"54" Willys M38A1
"65" M35A1 WW
To Many Others
Re: Rear Hub Sleeve
Agree with Tom-get a new nut. I recall (Charles I think) mentioning that even new nuts aren't always "true" and sometimes need to be surfaced to seal properly.
sturmtyger380
Re: Rear Hub Sleeve
Ah that makes sense. I need to clean those hub nuts and inspect them. This is the first time I have had any M37 hubs open. :oops:
Re: Rear Hub Sleeve
We typically repair and install sleeves on the outer nut flanges. We have had far greater success with this method than using so-called new nuts. They may be new, however the ones I have seen are far from quality pieces that a seal mates with successfully, we never had any luck with these stopping oil from getting into the hub. We machine ours accurately, install a sleeve, then do final machining steps to get a perfect outcome. Have had good results with this. If you have interest, send us some decent core nuts, we can rebuild and return.
