My truck is half stock and have modified .
Engine = Chevy vortec 350
Trans = Turbo 350 3 speed Automatic
Transfer case = NP200
Stock Axes with 583 third members
Brakes = Original Drums with Ugly truck duel Master cylinder upgrade : 1980 Chevy C30 1ton Master cylinder
Fuel Pump = 7 lb low flow electric
Power Steering = Snake River Conversion = Saginaw Unit
Tires = Interco Bias 15 x 39.5
Lift = 6 " Blocks between axles and springs welded to perch
Truck runs down the road great at 45 mph ,,,no problems ,,, I do want to remove the lift blocks and re arch the springs to get a 4 inch lift . I didn't do the lift mods with the blocks and re arching springs would be a much better option : don't have any issues with the blocks but wouldn't trust them off road . Engine and transmission set up works well and Rpm is about 3100 at 50 mph with no over heating issues . If you would like pictures I could send them to your regular email address . I hope this answers you questions Charles ...... you can call if you have any other questions thxs Dave Mowrey 717-877-2294
dmowrey3@comcast.net
Charles Weeks
- PFC
