u bolt dimensions
52PLOWERWAGON
u bolt dimensions
Post by 52PLOWERWAGON »
can some one please post the dimensions of the stock u bolts
I m looking to add some leaves to my suspension and i'd like to have ubolts before I start
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
Re: u bolt dimensions
The dimensions of the various spring "clips" are in the ORD 9 SNL G-741 parts manual. Multiple lengths depending on which truck (M37, M42, M43, V41) and which location on the truck.
Or just measure the ones that are on your truck now, and add whatever length you need to allow for the additional springs you plan to install?
52PLOWERWAGON
is there a special way to measure them ?
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
j mccormick
Post by j mccormick »
Measure overall length, inside radius and bolt diameter.
Joe
52PLOWERWAGON
that's what I thought just making sure
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
The ORD 9 SNL lists all of the clips as having the same width of 2-21/32", but that is not the opening, i.e. not the inside measurement between the legs. The inside measures 2-1/16" on an NOS clip that I have on hand, which will just fit over the stock spring width of 2".
You probably will have trouble getting the old nuts off of the existing clips, and they likely won't be (and shouldn't be) re-usable. All of the clips use the same nuts: p/n 7351124, 9/16-18NF. However, at 3/4", these are taller than a regular hex nut. You'll need something like these: https://www.mcmaster.com/#90565a333/=162gnss
52PLOWERWAGON
I figured if I can get ones that match i'll just torch them off
KILL IT WITH FIRE :mrgreen: :lol: :lol:
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
