Front Prop Shaft
sturmtyger380
Front Prop Shaft
Post by sturmtyger380 »
I keep digging into the M37 I have down here in South Carolina. I have all the floor covers off and noticed the front prop shaft is really gnarly.
Anyone have a good front prop shaft they would like to part with?
Alan
isaac_alaska
Re: Front Prop Shaft
Post by isaac_alaska »
most driveshaft shops can probably cut the bad section out and rebuild it for you for fairly cheap. i definitely wouldn't run it like that! it'll twist off in a second haha
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
BILL L
Post by BILL L »
Email me I might be able to help you. Autodoc51@aol.com Ocala,FL
Drew M.
Post by Drew M. »
To cut down a driveshaft at a shop is inexpensive (~$75). However, replacing the pipe or adding length is $$$$$! IMHO: Get a used driveshaft.
Oddball-CmK
Post by Oddball-CmK »
I believe I have one, the first one pictured without the yoke. If you're interested, $65 plus shipping.
Regards,
Cordell
sturmtyger380
I have a couple of leads at the moment but I will get back to you.
xm708
Post by xm708 »
If everybody falls through I have at least a dozen !!
