Ok, I just flushed and refilled my M37 cooling system. I checked the internet for capacity and found that it was 25 qts. Bought 3 gals distilled water and 3 gals straight undeluted antifreeze. Filled the system and found it would only take 4 gallons. Finally found the tm and it stated 18 qts. I'm assuming someplace somebody got it wrong to capacity. The site I looked at said that it was all the specs. as delivered to the US Army. I thought at first since I couldn't get the 25 qts in that I possibly had an air lock and I tried to bleed the air but it didn't make a difference. I drove a couple of miles and it never overheated and stayed at 160 deg. like always. Anyone else found the difference in specs?
CT
cooling system capacity
- Cav Trooper
- SGT
HHT 2nd ACR
1967/68
Chu-Lai, S. VietNam
1969
Cav Trooper
1967/68
Chu-Lai, S. VietNam
1969
Cav Trooper
isaac_alaska
Re: cooling system capacity
18 seems right, maybe 25 is if you have the additional heaters installed? i know i've drained a few and never had close to 25 qts
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
Fairbanks, AK
Photo Gallery
- Cav Trooper
- SGT
I have the fender mounted heater and still got 18 qts. Was just curious about what was in print.
HHT 2nd ACR
1967/68
Chu-Lai, S. VietNam
1969
Cav Trooper
1967/68
Chu-Lai, S. VietNam
1969
Cav Trooper
