Can someone tell me how to adjust the idle speed or tell me where in the manuals it is? Did a search here with no luck.
Idle speed
Idle speed
Gerry
53 M37
53 M37
Re: Idle speed
there is a screw on the carb where the throttle linkage is connected
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
Re: Idle speed
you can use an inductive tachometer, powered by a separate 12V battery, and replace one of the wires with a standard non-shielded wire, or use a spare wire or one with damaged shieding and pull the shield off in a section so you can access the core. inductive tach won't pick up the signal on a shielded cable.
you can also use a tach/dwell meter and read it right off the coil by pulling the big cover nut on the distributor housing and running your lead to there. you could also use a strobe on the fan, or a light sensing pickup on a fan blade.
but really what i do is just turn it down till it won't idle smooth and then turn it up just a hair
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
Fairbanks, AK
Photo Gallery
Re: Idle speed
Hi Gerry,
Idle speed of 600 - 650 works nicely.
If you have a vacuum gauge available it would be a good time to adjust your idle mixture screw for maximum vacuum, since your adjusting your idle speed.
