new water pump
bobcat1/178th
new water pump
Post by bobcat1/178th »
has anyone tried the new water pumps....are they U.S. made? reliable? they are supposed to have sealed roller bearings so no grease fitting.......
Jess
Re: new water pump
Post by Jess »
I got a new one from John Bizal at MWM. Its US made and didn't leak like my rebuilt NAPA one. Its been on my 251 CDN for a year and is fine. When I replaced the pump, I did a block and rad flush, new antifreeze and added a can of lubricant. So far, so good. The 251 in the M37CDN uses the same pump as the 230. John has always been good to deal with...
No grease nipple of grease cup on these.
carolinamv
Re: new water pump
Post by carolinamv »
If your M37's water pump has the cup then it wouldn't ever have the zirk fitting at the same time correct?
-Jay
MVPA#31295
http://www.mvcconline.org
3/3 CAV HWB
bobcat1/178th
Re: new water pump
ok thanks for the info.......
