750 flaps on 900 rims?
billy
Post by billy »
i have some 750 flaps that were sent to me by mistake
can i use them on my 900 budd wheels?
or should i send em back and try to find 900s?
Re: 750 flaps on 900 rims?
750 flaps are not as wide as the 900 ones and can not protect the tubes from wear like the correct ones will.
billy
Post by billy »
just got off the phone from LUCAS TIRES and according to them
they all take the same flap
Good information, thanks. Years ago the old 750s I was given were different so I now know they make just one for both.
billy
Post by billy »
Carter wrote:Good information, thanks. Years ago the old 750s I was given were different so I now know they make just one for both.
when i called
i started my question with
hello,i bought some 9x16 tubes and the flaps were.....
he interrupted and finished my sentence
your flaps say 750?
all the flaps are the same
it dont matter what width the tire
be it 6,7,9 or 10
52PLOWERWAGON
Post by 52PLOWERWAGON »
good to know 8)
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
isaac_alaska
Post by isaac_alaska »
Was it cheaper to get your flaps from Lucas tire than through vpw? I ask because I need to buy 4
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
billy
Post by billy »
isaac_alaska wrote:Was it cheaper to get your flaps from Lucas tire than through vpw? I ask because I need to buy 4
$15 each
isaac_alaska
very nice website, i'll be placing an order shortly. do our trucks (with stock rims) use the centered valve stem hole, or the offset valve stem hole?
Isaac
Fairbanks, AK
Photo Gallery
when i called
your flaps say 750?
be it 6,7,9 or 10
All flaps we have gotten in the last several years have both 7.50 and 9.00 stamped on them. We have had no problems; however I can't sit here and say yours are the same. Personally, I would have to seriously question it if 9.00 was not on it, there is simply too many people who will shoot you a line these days and won't give a second thought to your best interest. I'm careful whom I listen too unless it is someone I have confidence in.
billy
Post by billy »
MSeriesRebuild wrote:
when i called
your flaps say 750?
be it 6,7,9 or 10
lucas is a well respected company (i thought)
so i had no reason to think the tech was lying.
everything seems shipshape
so i got plenty of other things to worry about with the m43
