is there a source for the washers used on these trucks?
I'm trying to find a place to get a bunch of the "square" bolt washers (don't know the proper name). Is there a place?
Re: is there a source for the washers used on these trucks?
Snake River 4 x 4 has all but the 7/16ths. Paul
when I get back to the 37 I will try making my own washers out of stainless.......a chunk of threaded rod, two nuts, a stack of washers, a bench grinder with the right width stone and a steady hand should get the job something like.
McMaster-Carr also has them, look about a third of the way down the page:
http://www.mcmaster.com/#tooth-lock-washers/=yxs7z7
Try John at MWM or Snake River 4x4. If irrc, they have had them in different sizes along with bed screws we all eventually need.
Jess
Jess
I may order some of these in 3/8", just to see what they look like. Too bad they stop at 3/8". Still pretty expensive.Carter wrote:McMaster-Carr also has them, look about a third of the way down the page:
Shakeproof had 7/16" washers but destroyed the dies
I got some of the 3/8 washers from McMaster Carr, they are pretty close- the internal hole dia. is a little larger, and the internal teeth are smaller with more space between them. the exterior looks the same, with maybe a bit more aggressive edges.I sure wish it was easier to post pics here.
- SGT
Some of our vendors on here may even have some used that could be cleaned up.
