Fuel filter
Fuel filter
Is there a Napa replacement for the fuel filter?
Re: Fuel filter
Dutch,
Are you talking about the filter mounted up on the regulator bracket in the older trucks or the filter in the fuel tank in the newer M's? If you mean the in-tank filter they're repoping them now. John at Midwest has them as do most of the MV parts sources. If you mean the filter element for the older style mounted under the hood that's a bit tougher. I researched it last year and you need to look for Onan (generators) part number 149-1499 for the element. It appears they no longer make the element, so you have to find some new old stock. There is no Napa or Wix replacement. There isn't a replacement made by anyone that I can tell. They're around........I think there are some on Ebay, but be prepared to open the wallet wide.
Re: Fuel filter
Dutch,
This just popped up on Epay.
http://www.ebay.com/itm/NOS-USGI-Zenith ... fb&vxp=mtr
Re: Fuel filter
Is that the one that goes in the fuel tank?
