Con rod hardware
greencom
Con rod hardware
Post by greencom »
Hi all,
I need to know if reinstalling a piston and connecting rod into the M37 engine requires new bolts and nuts to be used in the bearing cap.
Thanks in advance.
Re: Con rod hardware
The TM9-1840A manual specifies new lock washers on the connecting rod bolts, but does not require new bolts or nuts.
However, I wouldn't re-use connecting rod bolts or nuts. New bolts and nuts are not that expensive, but failure would be.
greencom
Post by greencom »
Thanks Elwood,
I think that is the way to go too, any failure with these bits of hardware would be catastrophic.
