Test of Copy
With tutorials by Nivek.
Test of Copy
Monkey Man
Site Admin
Site Admin
Re: Test of Copy
Post by Monkey Man »
Looks Great Carter......and I "Might" have helped just a little by adding the link on a second line with the "Img" function :-)
MM
Trained Monkey on Guard
dodgem37@netspace.net.au
Re: Test of Copy
Monkey Man wrote:Looks Great Carter......and I "Might" have helped just a little by adding the link on a second line with the "Img" function :-)
MM
Not sure I understand what that is.
Monkey Man
Site Admin
Site Admin
Re: Test of Copy
OK, this is your link:
<https://scontent-lga1-1.xx.fbcdn.net/hp ... e=55F386AF> (remove "< >" from each end to see the link, I had to add them to disable the link function)
This is the modified link:
[img]https://scontent-lga1-1.xx.fbcdn.net/hp ... e=55F386AF[/img]
If you press the "Img" tab at the top of the post window it will add one of these:
[img][/img]
And you simply type or past your link in between:
[img]Image link TEXT or HTML[/img]
And your image should appear without the need to click a link :-)
MM
Tim Powell
Re: Test of Copy
Post by Tim Powell »
You Guys are getting way to technical for this old truckdriver!
Ain't no "high tech red-necks" over here in Iowa!
Sweet looking truck Carter!
Re: Test of Copy
Thanks Tim, just took a short 22 years of working alone and very part time to get it to this point. Only the welding was done by someone else, I did everything else.
Re: Test of Copy
Carter, your truck is the standard that I hope to attain next year when I go thru mine-depends on better body panels more than anything :)
Monkey Man
Site Admin
Site Admin
Re: Test of Copy
I think Carter's truck is the standard most of us hope to attain at some stage, there are some super nice restorations out there but Carters truck is not only a good looking rig it's been rebuilt to be used as a workhorse (pickup, low, tow rig etc., etc.)...
MM
Re: Test of Copy
Cal_Gary wrote:Carter, your truck is the standard that I hope to attain next year when I go thru mine-depends on better body panels more than anything :)
...better body panels... ? What is wrong with what you have Gary ?
Re: Test of Copy
Monkey Man wrote:I think Carter's truck is the standard most of us hope to attain at some stage, there are some super nice restorations out there but Carters truck is not only a good looking rig it's been rebuilt to be used as a workhorse (pickup, low, tow rig etc., etc.)...
MM
:oops: :oops: :oops: You are kind to say that Tony. Since I was that truck's assigned driver when I was in the NG I remember what it looked like back then and just tried to recreate how it was in ...1967-68
