Hub/Spindle Nuts
topellis
Hub/Spindle Nuts
Post by topellis »
Can someone tell me if the civilian power wagon has the same spindle/hub nuts as the M37? Just looking to source something local instead of having to order and have shipped.
Thanks for any info or part number.
Mark
Mark Ellis
1953 M37 WOW
1967 M101A1
USMC Retired
Re: Hub/Spindle Nuts
All I've seen on either was the same octagon shaped jobs.
topellis
Post by topellis »
PoW,
Thanks for the feedback but do you have any idea if they are the same size? I realize today some nuts are spline and such but octagon shaped can be about anything... about any size. I just wondered if they were the same. I don't know enough about Civie Powerwagons to know if the hubs are the same or not.
Mark
Mark Ellis
1953 M37 WOW
1967 M101A1
USMC Retired
Tom P
Post by Tom P »
The WDX-WM300-W300M (flat fender) Power Wagon uses the same hub,nut,bearings.
The W series, power giant, (conventional) Power Wagon trucks might be different as they used a Dana type axle.
Not sure about those. Most parts stores will be looking at the W series not the WDX-WM300.
TGP
"47" WDX WW
"52" M37 WW
"54" Willys M38A1
"65" M35A1 WW
To Many Others
topellis
Post by topellis »
Thanks! That's what I needed to know.
Mark
Mark Ellis
1953 M37 WOW
1967 M101A1
USMC Retired
