Ever Seen a Recapped NDT?
Hi Guys,
I saw this tire for sale on Epay and didn't think much of it........until I looked closer. It's a recap! I've never seen an NDT recapped, but I guess it makes sense. Look at the sidewall closely....you can see a bit of the original NDT sidewall, then a bunch of horizontal lines....and then the NDT sidewall starts again. And there's also that grove just off center of the tread, but only on one side. Interesting. Have you guys seen lots of these or was it fairly rare to recap a military tire. Did the military use recaps?
Re: Ever Seen a Recapped NDT?
Had 2 that came on my WC52 from Norway, I have seen a US Military manual that described the process so they must have used recaps at some time. Peace time army= save a buck.
carolinamv
Post by carolinamv »
Ive always been told with that groove cut in the tread that's how you can spot a re cap. Ive seen a lot of the on M35A2 trucks.
-Jay
MVPA#31295
http://www.mvcconline.org
3/3 CAV HWB
Monkey Man
Site Admin
Site Admin
Post by Monkey Man »
I have a recapped ("Re-Moulded") NDT, looks stock apart from a bit of a join line around the side wall, I can post a pic if you like.....
MM
Trained Monkey on Guard
dodgem37@netspace.net.au
Yes, recaps were used, but only allowed on rear axles; one of our other companies got failed on an AGI because some knucklehead put a recap on the front axle of a deuce....
sturmtyger380
Post by sturmtyger380 »
I have 4 Jeep size recap tires mounted on M151 rims. I got them cheap to use as roll around wheels for a frame. Alan
I've both 9.00-16 and 11.00-18 military recaps here.
Junk, OK for rolling around in the shop.
Dennis
52PLOWERWAGON
Post by 52PLOWERWAGON »
1 came on my 1952 will post pics asap :)
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
pwrwagonfire
Post by pwrwagonfire »
I had a re-cap with a 1952 date on it as a spare...ended up giving it away to a friend for his M101 trailer, because the thought of relying on a 60 year old re-cap in an emergency was scary!
-T
