I order a nos diff gear set but pinion gear isn't the same where the inner bearing goes and number on pinion is 922849 does anyone know what its for?? wc?? anyone interested to buy this set
Dodge had 2 sizes of ring and pinions in the axles 8 3/4 ring gear early vs 9 5/8 ring gear diameter late.
Check with a tape, slide rule m37's all came with 9 5/8 ring gear
Hope this helps you
Wc dodges had 8 3/4 in the beginning they change to 9 5/8 later
