I am looking for a rain cap for the fording kit intake pipe.
CT
rain cap
- Cav Trooper
- SGT
rain cap
HHT 2nd ACR
1967/68
Chu-Lai, S. VietNam
1969
Cav Trooper
1967/68
Chu-Lai, S. VietNam
1969
Cav Trooper
Re: rain cap
They didn't have one. The exhaust extension also did not have a flapper. You can certainly put them on, but you won't find any "originals".
I have a copy of the original Bill of Materials (it looks like a drawing). I can scan it and email it to you if you are interested. There is not much to it.
52 M-42
52 M-42
- milstencil
- CPL
Re: rain cap
Tractor supply has the rain caps.
Point it away from the truck or you will have little black spots from the exhaust
all over the truck.
I put a thin washer in the bottom bolt so that the condensation from the exhaust
would drain out and not be blown up the stack and on to the truck.
Rick
all over the truck.
Rick
- Cav Trooper
- SGT
Re: rain cap
Thanks, I'm looking for the intake rain cap, I know they were not issue but, I've seen them on other M37's and would like to find one. I don't need one for the exhaust.
CT
CT
HHT 2nd ACR
1967/68
Chu-Lai, S. VietNam
1969
Cav Trooper
1967/68
Chu-Lai, S. VietNam
1969
Cav Trooper
Re: rain cap
I used a M38A1 air cleaner pre filter on mine. It's a little bigger ID. so just wrap a strip of rubber around the top of the pipe and use a hose clamp or whatever to secure it.
- Cav Trooper
- SGT
Re: rain cap
Thanks Chuck, I found one commercially that should work.
CT
CT
HHT 2nd ACR
1967/68
Chu-Lai, S. VietNam
1969
Cav Trooper
1967/68
Chu-Lai, S. VietNam
1969
Cav Trooper
