Windshield Hold Down Brackets
topellis
Post by topellis »
Can anyone point me in the right direction to get a set of the hold down brackets or loops that are welded to the top of the windshield frame? I have the bumpers on the hood and the spring loaded hooks on the hood. Mine like many others after their military service have has them removed to facilitate a home made cab at one time. The welds are still on the frame. If it isn't practical to find a replacement... does anyone have a drawing or tracing and material thickness so that I could use that info to make my own?
I thought Midwest had them but I called and spoke with John and the part he has is for the canvas cab straps.
Thanks for any help,
Mark
Mark Ellis
1953 M37 WOW
1967 M101A1
USMC Retired
52 M-42
Re: Windshield Hold Down Brackets
Post by 52 M-42 »
I won't be taking my canvas top off of my truck for a few more weeks, but if you don't have the information you need by then, let me know and I will take pictures of the items you are interested in. I will put a scale in the photos so that you can get an idea of the measurements.
Good Luck and let me know.
52 M-42
topellis
Post by topellis »
Thanks, I will let you know if something else turns up. I guess I could cut one off of an otherwise trashed outer frame or make from scratch with a sketch.
Thanks again,
Mark
Mark Ellis
1953 M37 WOW
1967 M101A1
USMC Retired
topellis
Post by topellis »
52 M-42,
I received a picture of what I had been looking for today... so I am good to go. It doesn't look like it can be in place and have the CCKW hard top to me though... will take some measuring with the info I received today to figure it out.
Mark
Mark Ellis
1953 M37 WOW
1967 M101A1
USMC Retired
wvcharlie
Post by wvcharlie »
Mark,
I too had looked for those hold down brackets for my windshield. When I was out at the Power Wagon rally in Iowa a few years ago, we stopped in at Vintage Power Wagons. I asked them if they could cut the brackets off one of their M37 frames in the salvage yard. He said to just go pick a bent frame and bring it up to the garage. They zipped them off with an angle grinder for me. So, you may want to contact them. I would think they could fix you up as they had several bent windshield frames laying around.
Charlie
64 M38A1
65 M37
68 M725
101st ABN Veteran
