Opinions wanted
Opinions wanted
I've got a working LU-4, but the shift lever doesn't align with the stop holes.
I t's probably either a sprung shift fork or a worn shear pin.
Should I overhaul it, or install it as is and run it till it breaks?
(I think I already know the answer to this, but I need my willpower reinforced)
- MSGT
Re: Opinions wanted
You know it'll go all fubar when you need it the most... If its an easy fix, and its already off the truck, then just fix it now...
Re: Opinions wanted
Jim,
I would take the time to fix it now rather than later. You will save yourself time and aggravation in the long run.
Re: Opinions wanted
I wish ya'll were wrong - but, I know you're not
- Site Admin
Re: Opinions wanted
Your winch is the sort equipment that lends itself to utility, recovery and the possibility of emergency situations, make it good and make it reliable, no point in "almost" saving property or more importantly life, make it right
MM
MM
Trained Monkey on Guard
dodgem37@netspace.net.au
Re: Opinions wanted
I put an LU-4 on my 37 in 1962 back in my search and rescue days. Have never regretted it and only broke it once. Been meaning to put on on the 708 for a looonngg time. I have a talent for procrastination. No point in rushing now.
Re: Opinions wanted
I vote for a tear down and clean up. Then you know what you have and that it will last for the life of the truck. I bought one from Master Yota (Thanks Ray!) some years ago and after some indecision, disassembled, inspected and did some minor repairs. The shift lever was stuck due to corrosion but cleaned up ok. Although, I don't do a lot of winching, I know it doesn't leak on my shop floor, is up to snuff and will be serviceable when I really need it. There are a couple of very good write-ups around if you don't have one or any experience with these. This is the one I used for guidance:
http://imageevent.com/moosecreekmaple/l ... 421.eagle_
and another ugly one with good pictures... http://www.m715zone.com/vb/showthread.php?t=26151
Jess
Jess
Re: Opinions wanted
I've overhauled them before.
Just lazy.
Just lazy.
Re: Opinions wanted
LU-4s aren't cheap, and somewhat scarce anyway, so fix it now instead of inviting trouble (especially with Winter on the way).
Re: Opinions wanted
That's true. I paid $150 for this one. The one I got in 1962 was free.
- MSGT
Re: Opinions wanted
I'm glad to hear it worked out for you Jess! I was thinking about it the other day, and wondering if you'd managed to get it cleaned up and installed...Jess wrote:I vote for a tear down and clean up. Then you know what you have and that it will last for the life of the truck. I bought one from Master Yota (Thanks Ray!) some years ago and after some indecision, disassembled, inspected and did some minor repairs. The shift lever was stuck due to corrosion but cleaned up ok. Although, I don't do a lot of winching, I know it doesn't leak on my shop floor, is up to snuff and will be serviceable when I really need it. There are a couple of very good write-ups around if you don't have one or any experience with these. This is the one I used for guidance:
Jess
Re: Opinions wanted
One of the stud holes for the 1/2-13 x 1/2-20 double ended studs that mount the side brackets on my LU-4 is wallowed out.
As I see it, I have two feasible options
1) Overbore and helicoil back to 1/2-13
2) tap case for oversize double-ended stud 17/32-13 x 1/2-20 (stud might be hard to find)
Any thoughts?
Any thoughts?
Re: Opinions wanted
Depending how enlarged the threaded hole is I would do the Helicoil option first. If it's too enlarged for the Helicoil, I would go with a EZ Lock threaded insert.
Re: Opinions wanted
Presently, hole size is such that a 1/2-13 will 'hold' or 'take', but wobbles. Not very strong and could easily strip.
