M37 Dodge front & rear shocks
John G
Post by John G »
I have just crossed referenced the correct part # from Gabriel shocks for the
front shocks it is Gabriel Fleetline shock # 85305 425mm compressed to
692mm extended.Called Gabriel and they also checked!
The question I have has anyone cross referenced the part # for the rear
shocks.If so I would appreciate the help.
Purchased the 2 front shocks from TruckSpring.com for $ 45.04 ea.
this morning.
John G
Ray505
Re: M37 Dodge front & rear shocks
Post by Ray505 »
John:
The Gabriel Fleetline Shock numbers I used are Front=85303 and Rear=85302. The front shocks fit perfect but, on the rear the driver's shock seemed to be a little short in length. The only thing I can think of is the driver's side has more leaf springs as my truck is an M37B1. Also, try searching a shock number one digit higher or lower than the pair you ordered. That may give you the matching pair for the rear.
squeeky0_50
Post by squeeky0_50 »
Last time I bought shocks for the M37 were monro-magnum 70 shock absorber. These are the same diameter as the nos but do not have the lower collar on the bottom. Part # frt. 74025, rear 74029. Rears are a little longer. I have a 1987 master catalog that I saved. It lists these for tractor trailer and buses. Hope this helps. They are available on various internet sites.
vargaspj
Post by vargaspj »
You might try Monroe 74424 on the rear (I did).
M37 Shock Comparison Chart 5.doc
(68 KiB) Downloaded 480 times
