Battery cable
Battery cable
What is the proper routing for the positive battery cable?
DA Supply Weenie
President Michigan Military Technical & Historical Society Museum
http://www.mimths.org
1942 Ford GPW
1942 Chrysler Fire Pump
1943 Hudson Invader
1944 WC-52
1951 M100
1952 M-37
1985 Dodge W-150 (Ex-Air Force line truck)
1942 Ford GPW
1943 Hudson Invader
1944 WC-52
1951 M100
1952 M-37
Re: Battery cable
OK I'm going to give this a shot, 1, after leaving the battery box and passing thru the cab floor. It heads forward, one clamp about five or six inches from the hole it came from and then another clamp about a foot away from the first one, Then it goes over the rear motor mount and up over the bell housing, A clamp attached to the fuel system linkage on the right side of the motor.2 then at the hump for the starter it turns and goes to the starter. Hope this is well. This is from My 51 M37.
