Turn sig help. new install
I put in a complete new wiring harness but my turn signals(solid state) do not work. The light on the lever goes on but no flashing or lights on the tail lights.Any ideas? All the rest of the lights work on the truck.
Gerry
53 M37
53 M37
Re: Turn sig help. new install
Did you check that the flasher unit was grounded properly? Check the supply wire (24v) and make sure the power is getting to that section of harness.
-John
Member of Dixie Division MVC
1953 USAF M37 wow, restored
1953 USMC M37 w/w -in storage
1967 M116A1 Pioneer Trailer
S-89 Comm box
S-89 Comm box
I have a good ground. Light on lever goes on so power there. Anyone else have any thoughts?
Gerry
53 M37
53 M37
Since you have no lights, check that the tail lights are grounded. The turn signal lever also needs grounded by the steering column, you may need to remove some paint.
You have a ground issue on one of your lights, check the right ones. See to make sure you did not pinch something somewhere in your wiring.
http://linehaulrvn.tripod.com
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
All the lights work except the flashers All rear stop run and blackout work
Gerry
53 M37
53 M37
I can help you straighten this out, several areas of concern, but likely nothing of a serious nature going on. It is not a ground issue at your light fixtures if you have other lights working. The switch being grounded at the column jacket is only so the pilot light on the switch lever works, that doesn't matter to the system in general. If you are using the military spec flasher, it must be grounded, if you are using a conventional, non mil spec flasher, most require no ground, with the exception of a couple of specialty types.
Shoot me an email or call me (704-474-4683) so I can verify a few things, happy to help you.
Charles,
I am using a vintage wiring harness. Hopefully have time in the next couple days to give you a call during the day.
Gerry
53 M37
53 M37
OK, I'll try to help. Will be out a good portion of Thursday, should be here any other day.Gerry wrote:Charles,
- m37jarhead
Gerry and Charles:
Please post the results of your "fix".
Tks,
Jerry
Tks,
Jerry
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
Past Pres
Member: MVPA #26600
Member: NRA
