Greetings all,
I was cleaning up my bow corners and noticed a difference in the bolt holes. The difference was in how they were punched out-some with the "rectangular" hole squared with the bow corner, the hole sides running parallel to the bow, and some with the hole punched about 45 degrees rotated, like a "diamond." In the photo, the left one has the diamond hole and the right one has the rectangular holes. Notice how the left one has more of a diamond look to the hole whereas the other has more of a rectangular look in relation to the lay of the bow corner. Elsewise, they are identical and interchangeable.
I wouldn't have noticed it except I was thinking about putting the roll-up straps on and the diamond cuts don't line up with the strap brackets and the carriage bolt.
What gives? Are the diamond holes not M37?
Bow Corners
Bow corner bolt holes
