Ok I need some parts
- SGT
Ok I need some parts These are the parts I need: the whole carb setup including the air cleaner, the top draglink, all glass, wiring harness front and back, gas tank, the U joint looking thing for the steering rod that holds it to the dash (lol), distributor, and 24v generator.
Thanks.
Thanks.
- PFC
- SGT
new list: the air cleaner, the top draglink, all glass, wiring harness front and back, the U joint looking thing for the steering rod that holds it to the dash (lol), distributor, and 24v generator.
Parts.
Bubba;
Have you contacted Sid Beck, or John Bizal at midwest mil? Either of the gentlemen are top choice for me for parts. They should easily have the parts you mention aside from maybe the generator, although I doubt even that will be too difficult to obtain.
Re: Parts.
Ditto on Sid & John.Nickathome wrote:Bubba;
Just a thought - unless you want to stay original, you may consider using a 24V alternator to replace your generator/regulator. A 60A one will run you about $125 - at least when I got mine...
I have a rear harness I bought from Sid in Feb and ended up not using it. It is one of his foreign stock NOS parts with douglas connectors. We ended up using a new fuel sender, rear lamps, and we added in some rear back up lights - all with packard connectors. I would have had to hack up a nice stock harness and couldn't do it - so we made our own rear. Its your at what I paid if you want it. Keith
- SGT
- SGT
I may already have a harness but if not I will let you knowknattrass wrote:I have a rear harness I bought from Sid in Feb and ended up not using it. It is one of his foreign stock NOS parts with douglas connectors. We ended up using a new fuel sender, rear lamps, and we added in some rear back up lights - all with packard connectors. I would have had to hack up a nice stock harness and couldn't do it - so we made our own rear. Its your at what I paid if you want it. Keith
- SGT
These are the must haves. wiring harness front and back, the U joint looking thing for the steering rod that holds it to the dash (lol), distributor, and 24v generator.
- SGT
Does Sid have a website ?knattrass wrote:The one from Sid has the colored wires and he provided a cheat sheet on the connections. The wiring inside is fresh and the outer wrapping is the newer type of non sticky tape. I'll look for the invoice and get you the price.
- SGT
