Have fun with this thread and remember to post pictures if you can
MM
g741.org
M37 Discussion Forum |
I did 2,5(not sure of filter sizes), 6,9, and 11.Sal wrote:I would say that all the mod's I made were practical ones...
1- LED Headlights
2-Free Wheeling Front Axle Flanges
3- Electric Wipers
4- Replaced Incandescent bulbs in Stop light and Directional's with LED's
5- Electric fuel pump with 100 Micron filter before the pump and a 10 micron filter before the carb.
6- Gamma-Goat style tail light lens
7- Digital volt meter
8- Mechanical oil gauge
9- Replaced point and condenser with Petronix unit in the Distributor
10- Installed a tap before the PCV valve so I can use a vacuum gauge.
11- A conical shaped high-flow air filter... Taken from my son's Camaro...heheeh
12- 24 to 12 volt step down converter. If I want to run a radio or CB.
Sal
