Where does the Battery to ground cable attach to the truck? The same spot as the engine ground strap?
Battery ground location.
Gerry
53 M37
53 M37
Re: Battery ground location.
If I recall it attaches to the frame under and to the rear of the battery box.
- m37jarhead
My battery ground is almost immediately to the right of the bell housing, on the frame. The ground off the bell housing is attached there too.
Don't know if this is the mil-spec location.
Jerry
Jerry
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
Past Pres
Member: MVPA #26600
Member: NRA
Thats what i thought might be the spot but if I read the manual correctly the ground cable is 2 ft long so I dont think it would reach there
Gerry
53 M37
53 M37
- m37jarhead
If we assume the 2' long ground cable is correct, than you might try to find an existing hole in the frame
that can be reached with the 2' cable.
JB
JB
Past Pres
Member: MVPA #26600
Member: NRA
Past Pres
Member: MVPA #26600
Member: NRA
