Where is the correct location to mount the turn signal relay box that is included in the 50's turn signal kit?
Rick
Re: turn signal relay box
I can't say if it's the correct location, but mine is attached to the bracket for the voltage regulator off the driver's side firewall.
I thought it bolted onto the left side of the glove box. That is where I mounted my flasher unit.
Tim
Tim
Like Tim, I mounted mine onto the left side of the glove box.
From TM 9-2320-212-20, page 2-68, paragraph 2-47
Turn signal relay (distribution box).
a. Replacement.
( I ) Place vehicle light switch in OFF position.
(2 ) Open glove compartment and remove the
two hex-head screws, washers, and nuts securing
box to compartment (left side)
(3 ) Remove distribution box from under dash
panel and gently pull toward self as far as harness
will allow.
(4) Remove one wire at a time and install on
replacement box before removing any others.
Continue removing and installing wires to the
correct terminals of replacement box.
(5 ) When all wires are installed, position box
under dash panel on compartment side wall. and
install two hex-head screws, washers, and nuts.
Install ground wire M simultaneously with front
screw.
a. Replacement.
will allow.
screw.
Anyone got the wiring diagram for this set up???
http://linehaulrvn.tripod.com
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
This is the wrong diagram. This is for the solid state system. The thread discussion is for the older system with the distribution box.
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
Try this, left click on "full screen" then again on the image to view enlarged.
http://news.webshots.com/photo/23207432 ... 7451eirUSS
The 1963 MWO for the turn signal kits, with the older, non-solid state flasher, shows the "typical" location for the 3/4 tons is on the inner left fender. The text accompanying it states: "Locate distribution relay box 8683529 in the most convenient place in the engine compartment making sure that leads from the directional control will reach the relay box terminals."
- 3/4 Ton Location-Typical, circa 1963
- MWO Turn Signals_3Qtr Ton Installation-Typical (1963) (Small).jpg (46.77 KiB) Viewed 1382 times
