Two options as I see it, based on how it's drilled:
If you can apply heat around the stud remnants to expand the manifold it will probably come right out with your extractor;
Or, use a chisel, and hammer the thicker wall area (about 2 and 4 o'clock) inward-this should collapse the remnants enough for you to get a pair of needle nosed vise-grips or pliers on it and turn it out.
Extractors need to be perfectly centered in a drilled hole to run the least risk of breaking one. You'll also want to use a quality extractor. I'm sure I could remove it if it were in front of me, as I've had lots of practice.
Good luck-let us know how it turns out (no pun intended)!
Not sure I'd use an extractor as that metal at 6-8 o'clock looks real thin. I'd be afraid of damaging the threads. Gary seems to have the best idea so far, if it were me, I'd probably grab a Dremel and remove as much as I could that way. Lots of heat and penetrating oil. Whatever you do, chase the threads with the correct tap when you get it out.
