Valve seat part numbers?
refit1701
Post by refit1701 »
Anyone have the exhaust seat part number handy? I want to replace all my exhaust seats and valves in this engine.
-John
Member of Dixie Division MVC
1953 USAF M37 wow, restored
1953 USMC M37 w/w -in storage
1967 M116A1 Pioneer Trailer
S-89 Comm box
achiem37
Re: Valve seat part numbers?
Post by achiem37 »
I have this sealed power # for a exhaust seat in a 230 L head engine # 245-1625-1 standard material and # 245-1625-1N for premium material.
refit1701
Post by refit1701 »
Thanks, I appreciate the info.
-John
S-89 Comm box
refit1701
Post by refit1701 »
That number doesn't seem to work anymore. I looked at the M37 parts replacement pdf on Garbee's site and those numbers aren't working either.
Can someone point me in the right direction for these exhaust seats??
-John
S-89 Comm box
achiem37
Post by achiem37 »
If your truck gas the 230 engine go to RockAuto.com input a vehicle like a 55 Dodge Power Wagon with the 230 engine and go to the engine parts page under valve seats. They are available for around $3-7 each. If your truck has the 251 go to a 61 or older Power wagon and do the same thing. This is where I found the original number as the engines are the same mechanically except for a few minor things.
refit1701
Post by refit1701 »
Thanks, I will try that!
-John
S-89 Comm box
refit1701
Post by refit1701 »
I think I figured out part of the problem. All anyone lists is the intake seat, which stock engines didn't have AFAIK. The above part number is an intake and is the wrong size. I have the dimensions of the original exhaust seat but am having a devil of a time finding a match at NAPA online, etc.
This leaves me with the unpleasent task of actually going down to NAPA and having them stare at me when I tell them what it is for, since that is all they know to ask.
-John
S-89 Comm box
achiem37
Post by achiem37 »
Sorry the parts are not what you wanted. I should have measured mine to check for intake versus exhaust seats. VPW has the seats advertised on their engine parts page. Part #CC868888A at $42 a set for a 230 or 251.
I can get you some valid #'s on Monday at the shop. Most of the time we counterbore and replace the intake seats also. Let me know if this will help and I'll make a note so I don't forget to get the info.
refit1701
Post by refit1701 »
Hi Charles,
If you could post those numbers I'd appreciate it. I am evaluating the intakes now.
John
-John
S-89 Comm box
refit1701 wrote:Hi Charles,
John
The numbers are SBI brand, SB1516E-1 Exhaust, SB 1625-1 Intake. Block must be counter bored to accept the intake seats if they must be replaced.
refit1701
Post by refit1701 »
Thanks Charles!
-John
S-89 Comm box
