Wiring Harness Stock # 0741-73-51055 P/N 7351055
52 M-42
Post by 52 M-42 »
Does anyone have any idea which wiring harness this is? I found this in my storage unit (it is still sealed in the box) and I didn't want to open it if I don't have to.
Any help would be appreciated. I already searched the net under both numbers.
Thanks in advance for the help.
52 M-42
Glenn
Re: Wiring Harness Stock # 0741-73-51055 P/N 7351055
Post by Glenn »
Parts book says it's a body harness for M37, M42 and V41 through serial number 80025704.
52 M-42
Post by 52 M-42 »
Thanks, Glenn!
By the "parts book" do you mean the SNGL (sp?)?
Unfortunately I don't have that book, which is why I was asking for help. Did the book tell you whether it was the front or rear harness?
52 M-42
Glenn
Post by Glenn »
ORD 9 SNL G-741 :) That should be for the cab, if by rear you mean chassis there is a separate one for that.
