Carb rebuild xtra part
Gerry
Post by Gerry »
Putting my carb back together and I have an xtra part :oops: can anyone tell me where it goes. I cant find it in the manual or schematic.
Gerry
53 M37
afvet6670
Re: Carb rebuild xtra part
Post by afvet6670 »
Maybe the rebuild kit's for more than one mod of crab?
Carl
53 Air Force M37 w/o/w
66 M101A1
afvet6670
Post by afvet6670 »
OOPS, that should be carb not crab... :oops:
Carl
66 M101A1
Gerry
Post by Gerry »
im pretty sure it came out of the carb. Doesnt mean it was done right the last time.
Gerry
53 M37
flobble
Post by flobble »
Don't you love it when you find these "bonus" parts! It doesn't look familiar, and I just rebuilt mine 2 months ago. On a side note, when I tore mine apart there was a small copper rivet in the accelerator pump housing. I have no idea how it got in there, or why it never affected the function of the carb!
Rick C
Post by Rick C »
Looks like it goes in the needle. the float presses on the pin..... just my opinion
Rick C
Gerry
Post by Gerry »
thanks Rick will take a look later today.
Gerry
53 M37
Rick C
Post by Rick C »
Gerry if you take out the needle valve, some of the needles have a hole in the back side. The spring goes in with the pin sticking out the back. Thats what it looks like to me. At least if thats what it is you don't need to take your carb apart.
Rick
Glenn
Post by Glenn »
I think Rick pretty much nailed it.
The parts pictured are way too large to be from the spring and pin type needle assy.
I've built many of these carbs, don't recognize these items as being from an ETW1.
Gerry
Post by Gerry »
Thanks all. The rebuild kit came with a new float needle so if thats the case i dont need anyways.
Charles I was hoping you would give your advice. I figured you have seen a few of these.
Thanks again all,
Gerry
53 M37
Gerry
Post by Gerry »
Rick,
You nailed it on the head. The old needle had the hole and the parts fit perfect. Checked new one and it was solid no hole. Now I can relax and not worry :D
Gerry
53 M37
ODUSAOK
Post by ODUSAOK »
Greetings Folks,This is my first posting on what has been a very interesting and informing site .I decided to get out of the guest status and jump in.The older carb kits came with the spring loaded needle valve you removed as replacements for the original setup.The newer kits have done away with those parts in favor of the simpler solid needle.THe theory for the spring loaded setup was that during rough travel the spring would help to keep the needle in the seat when fuel wasn't actually needed, to avoid a flood condition.I've rebuilt ,and then used off road,carbs on trucks with both setups.It didn't seem to make a difference in the real world,not in my experience at least.I wouldn't relegate the old parts to the trash in any case unless they were actually worn.The way things are going,items are only getting scarcer.
Gerry wrote:Rick,
It looked bigger in relation to the dime to me. The Japanese kits used to have that type set up, but they have been gone now for a few years.
Hey welcome to the forum ODUSAOK-glad to have you with us!
