clutch alignment tool
Gerry
Post by Gerry »
Any one have a part # or specs for the alignment tool that I can use at a local parts store?
Gerry
53 M37
Re: clutch alignment tool
I don't have a number but you can get an input shaft from AB Linn-mine was $10.
Gerry
Post by Gerry »
wish I had asked earlier I just got a package from him today. I think the tool should be cheap locally. the shipping would kill me from A B
Gerry
53 M37
W_A_Watson_II
Post by W_A_Watson_II »
Picked mine up at a Clutch Shop for a couple of bucks.
Will
1946 Dodge Power Wagon
My 1953 Dodge M37 WEB Site
Any auto supply will have a universal alignment tool kit; however the input shaft from the transmission can't be beat for this purpose. Much more precise than a universal tool; it's what we use all the time.
Gerry
Post by Gerry »
Thanks all,
Gerry
53 M37
m37jarhead
Post by m37jarhead »
Just finished hanging the pressure plate and clutch disk. Used a length of 3/4" steel rod to align the disk while tightening down the bolts on the pressure plate. Then I mated the tranny with the engine. All went together slicker than snot. Might not be "the" most correct way to do it but worked for me.
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
