CHECK N FILL
anthony manzella
CHECK N FILL
Post by anthony manzella »
The gear lube is there just the 1 plug in the pumkin or is there a way to drain and then Fill . :oops: :?:
Hit Duh Ground Runnin
powerwagontim
Re: CHECK N FILL
Post by powerwagontim »
Hi Anthony,
There is a drain plug at the bottom, and a fill plug on the side. Fill it to just below the level of the side plug.
Tim
anthony manzella
Re: CHECK N FILL
Thank You ! I thought so but I had my dought's 8)
M37UK
Re: CHECK N FILL
Post by M37UK »
anthony manzella wrote:The gear lube is there just the 1 plug in the pumkin or is there a way to drain and then Fill . :oops: :?:
hey Anthony, I know its hard to believe but the military actually produced manuals showing you this kind of stuff . :mrgreen: :mrgreen: :mrgreen: :mrgreen:
You need to get some, quick !! :D
Stu
MVT UK
SMVG Scotland
Re: CHECK N FILL
You should also know that the drain plug does not offer a complete drain because it is not at the low point of the housing. It leaves approx 1/2 pint of fluid that can't be drained. If there is water or debris in the housing; it will remain and will contaminate the new oil immediately as any water will be on the bottom. A little extra trouble, but the smart thing to do is remove the differential from the housing and give it a good cleaning before adding new oil. You can also do a visual inspection to be certain that anything you can see is up to par. Drill and thread a new drain plug hole at the low point at the same time eliminating the incomplete drain issue in the future.
anthony manzella
Re: CHECK N FILL
I Have Been Trying To Find One In Scotish But Keep turning up M/T Handed. :lol: Me Ladd :mrgreen: . "found my old rag of a book under all the stuff from my last project"
