overdrive options available now
for anyone repowering and using the spicer 3053 trans, there is now a overdrive upgrade kit available so you do not need to change axle ratios etc. see http://waterloospecialties.webs.com/
Re: overdrive options available now
CAN THE SPICER TRANSMISSION MATE TO THE 230?
i doubt the 230 would have enough power, the most common situation is a 4BT with the spicer 3053
