Voltage Regulator rebuilds
I know this topic has been addressed many times but I have found a company in California that specializes in rebuilding the voltage regulators for the M37's. They do AutoLite and Delco and are very reasonable and also just plain good people that will take care of you. They will custom rewind coils if needed and also adjust your regulator WITH the aluminum cover on to make sure the magnetic field is set precisely. There name is C.P. Generator, Eric Perez at (213) 746-1060. Hopefully this is ok with you guys that I posted this info because I have spent many days trying to find someone who can fix these things and also know what they are doing.
The Good, The Bad and The Ugly
Re: Voltage Regulator rebuilds
Interestingalso adjust your regulator WITH the aluminum cover on to make sure the magnetic field is set precisely.
Also since the covers have no adjusting holes in them I wonder how they would adjust the regulators with the covers on?
You mean to say that you can't pick up the cover with a magnet?
Sometimes ya just gotta shake your head, don't ya?
