6 volt start problems
wvcharlie
Post by wvcharlie »
My M37 had been converted to 12 volts when I got it. It has a six volt starter as is common with these conversions. My mechanical starter switch that is mounted on the top of the starter went bad. I ordered one from Vintage Power Wagons, but it wasn't the right one. Does any one out there have either an used starter or just the switch. It is impossible to tell what this starter came off of, but the tag has this info:
Chrysler part no.920344 Autolite no. MAW-4029
I have a 318 V8 I am planning to put in this summer and I hate to buy a new starter just to use for six months or so. Any help would be appreciated.
Charlie
64 M38A1
65 M37
68 M725
101st ABN Veteran
peter e mark
Post by peter e mark »
Hello, And the mechanical starter switch you refer to, is this a switch that is pushed by a foot pedal linkage arrangement, like in the WC series trucks?
1952 M37 W/W
wvcharlie
starter switch
Post by wvcharlie »
Yes, that's right. That metal housing with the spring plunger contact that is attached to the top of the starter. Vintage Power Wagons said there were several different ones used, but they only carried one.
Charlie
64 M38A1
65 M37
68 M725
101st ABN Veteran
