Winch cable
Cav Trooper
Winch cable
Post by Cav Trooper »
I know that the original winch cable was 7/16 fiber core. Is there problem using steel core cable?
HHT 2nd ACR
1967/68
Chu-Lai, S. VietNam
1969
Cav Trooper
Re: Winch cable
I wouldn't think there'd be a "problem," per se. The fiber core is more flexible and the steel core is stronger. You just have to decide which one will best suit your needs. Price and your budget may be a factor, too. ;)
Re: Winch cable
The original cable with the hemp core is a 6X19, 19 wires each in a total of 6 strands. If you use a 6X19 with an independant wire rope center (steel core) it will be so stiff you will have problems winding it on the drum and it will give you constant issues with handling each time you use it.
On the other hand, you can use a 6X37 cable with the wire rope center, it will be just as flexible as the 6X19 original and far stronger. Flexibility is determined by the size of the wires in each strand. 37 wires in a strand in place of 19 wires making up the same size strand adds a huge amount to the flexibility factor.
We use 6X37 with a wire center 1/2" diameter cable on all ours. works great, winds tight on the drum and is a good bit stronger than the 7/16" cable. The drum will hold 175' of 1/2" with room to spare
