It seems there are various spider harnesses available. What is correct for an M37? I also seem to recall folks using spiders with more legs than needed, and using the extras to power extra circuits? any comments or insights appreciated.
Tim
Spider wire harnes question
Re: Spider wire harnes question
If you have a voltmeter you need 5, one for power in and 4 for power out including to the voltmeter.
The #27 instrument cluster wiring spiders came in several forms. Early M37 used the 4 leg Douglas connector. M37's with Packard rubber connectors used the later 4 or 5 leg depending on weather it still had the amp meter or used the volt meter.
Later 5 leg Packard with rubber connectors.
Early Douglas 5 leg used when you need the power to the forth instrument.
Tim,powerwagontim wrote:It seems there are various spider harnesses available. What is correct for an M37? I also seem to recall folks using spiders with more legs than needed, and using the extras to power extra circuits? any comments or insights appreciated.anTim
If you find and use a Canadian M-37 harness, their trucks had a couple of extra features and they have come in handy for extra power feeds for our uses.
http://linehaulrvn.tripod.com
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
