Question for Charles
Josh
Post by Josh »
Charles, where do you get your 4Bt's? I assme they are new, and, how much?
Thanks. Josh
M37UK
Re: Question for Charles
Post by M37UK »
I'm not sure you'll like the answer to that question Josh as I asked the same thing little while ago.
Stu
MVT UK
SMVG Scotland
We get our engines from a factory direct Cummins distributor, yes they are brand new and equipped to our specs. when delivered to us. Cost depends on the particular model chosen and various equipment options you may choose. You would have to get more specific in order to nail down a cost figure. As of 1-1- 2010, the 4BTA engines are only available as a Cummins ReCon engine, factory reman that carries a new engine warranty. These are no longer built as new because they do not comply with federal mandates for new engines. The reman 4BTA actually cost more than a fully compliant all electronic engine; cost went up a flat $1,000 per unit as soon as the word came down to stop production.
