Battery Box
sturmtyger380
Battery Box
Post by sturmtyger380 »
I got my battery box done and installed last weekend before the snow this week. After not being started for 4 months, I primed the carb and she fired right up.
Lookin' good, Sturmtyger! BTW, I like WWII German armor so your forum name caught my eye as soon as you registered.
TOM R
Post by TOM R »
looks great, need to clean and install ours but the aftermarket batts we have are to big to fit :?
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
N1VSM
"Oversized" Batteries
Post by N1VSM »
TOM R wrote:looks great, need to clean and install ours but the aftermarket batts we have are to big to fit :?
If you take out the 4 bolts on the floor inside the battery box (thanks sturmtyger for the great picture!), you can remove the battery hold-down, and then rebolt the box to the floor. I stuck 2 group 24 batteries in and they just barely fit. I also rigged up a tie-down so that when I turtle my rig :shock: the batteries won't short out on the box cover.
Tom @ Snake River
Post by Tom @ Snake River »
It helps greatly to stick a chunk of conveyor belting in the bottom of the battery box, just some kind of material for the battery acid to sit on instead of down on the fresh paint and metal. Tom
www.snakeriver4x4.com
G-7117 Chevy
TOM R
Post by TOM R »
ok thanks we will try it :D
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
N1VSM
Pics
Post by N1VSM »
Don't forget to post pics of the final product. :)
ELBUFO
Paint
Post by ELBUFO »
Now that your box is all perdy, go to the hardware store and get a couple of rattle cans of appliance epoxy paint I have found it in white and black. mask off the box about 4" from the bottom lightly sand and hose'er down. Epoxy resists acid way better than enamel or lacquer. If you must have a nice green box, re-shoot it. Even when the acid eats the green, it will still have to get through the epoxy before it lunches on the metal. We did this a lot during my days in vehicle maintenance in the AF. If you have trouble coming up with the converyer belt, stall mat (horses etc.) would work. The best maintenance however is inspect and clean often...John
peter e mark
Post by peter e mark »
That sure is a great picture . You all speak of battery acid damage. Will I damned eternally to "Restoration Hell "if I use jell batteries, Like the Ultima 1000 amp red tops?
1952 M37 W/W
TOM R
Post by TOM R »
if they fit use em they seem to last longer from what i've seen
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
TOM R
Post by TOM R »
ok we are back to workin on this batt box since it is warm today and dad got some smaller batteries, so on the bottom of the box itself one of the large holes had what looked like a rubber grommet on it , are there supposed to be these rubber grommets on all the holes on the bottom of the main batt box between it and the floor?
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
I think those are rubber drain tubes an inch or so long-don't know where to get any (and I need 'em too).
TOM R
Post by TOM R »
thanks gary, there was only 1 on the box and there is so little left i thought it was a grommet to dampen vibration or something
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
N1VSM
Drain Tube
Post by N1VSM »
Cal_Gary wrote:I think those are rubber drain tubes an inch or so long-don't know where to get any (and I need 'em too).
There is one drain tube. In the pic that started this thread, you see that in the bottom of the battery tray, there is an indented "X". In one of the arms of the "X" is a hole - in the upper-right in the picture. When the tray is in the box correctly, you'll see that there is a hole in the cab directly under the hole in the tray. I made a drain out of copper tube (sorry - don't remember the dimensions! :roll: - but it was about 3" long). Use something to flare one end of the tube. That way you can slip it down through both holes, and it won't fall all the way out. The fun part is figuring out how to tack it down so that the acid from your exploding battery doesn't seep around the edge. Don't remember how I did that either. :roll: :roll: I see the drain as more of a water drain for when you go playing in the mud. :)
TOM R
Post by TOM R »
ok thanks, so i figured then that the 4 big holes on the floor under the box get grommets to isolate the batt box from vibration?
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
