Damn! Can't find my parts book and need to order. Can somebody give me original and NAPA number for points on my '53?
Thanks!!
Chuck
Need Part number for points
Re: Need Part number for points
Auto-Lite / Prestolite # IGP3028FS
Bluestreak # AL-4556xp
Thanks for advice, guys. "Preciate it!
NAPA Echlin points are CS725A, Condenser is AL869Riverrat wrote:Thanks for advice, guys. "Preciate it!
Sort of off topic, for a 230 that has been converted to 12 volt, would the same point/condenser #'s apply?
Bruce that would depend on which distributor you have IE the military using a 12 volt internal or external coil or one of the many civvy distributors. IE
IAD-4201-1 uses IGP-3028FS & IGW-3139 Early distr with fan shaped rotor & 3 3/8" dia. base
IAO-4102-1 uses IGP-3028FS & IG-3927K Early distr with fan shaped rotor & 3 3/8" dia. base
IAY-4002-1 uses IGW-3028DS & IAT-3076LA Late with short roundish rotor and 3 1/8" Dia. Base
IAY-4006-1 uses IGW-3028DS & IAT-3076LA Late with short roundish rotor and 3 1/8" Dia. Base
IAY-4003A-1 uses IGW-3028DS & IAT-3076LA Late with short roundish rotor and 3 1/8" Dia. Base
IAY-4003-1 uses IGW-3028DS & IAT-3076LA Late with short roundish rotor and 3 1/8" Dia. Base
IAY-4003B-1 uses IGW-3028DS & IAT-3076LA Late with short roundish rotor and 3 1/8" Dia. Base
I'm heading out the door for a couple of days, my coil is external. Also my 230 is from a 43/44 WC.
A more direct answer to your question, the points that work in the military standard distributor do not fit in any of the civilian distributor models.m-37Bruce wrote:Sort of off topic, for a 230 that has been converted to 12 volt, would the same point/condenser #'s apply?
Condensers are more easily adaptable, various ones can be made to work in many distributors without a lot of effort.
If it still has the 43/44 T223 distributor then IGW-3028DS & 1BB-2042SS 1
