knuckle flange gasket
Gerry
Post by Gerry »
Is there a gasket that goes between the outer face of the flanges and the spindle(hub assembly)?
Gerry
53 M37
Re: knuckle flange gasket
Gerry wrote:Is there a gasket that goes between the outer face of the flanges and the spindle(hub assembly)?
No gasket was used here, however if you do not seal the flange with anaerobic type gasket maker, the oil in the grease will seep constantly, especially in hot weather.
Gerry
Post by Gerry »
Thanks Charles
Gerry
53 M37
