Doing a little cleaning out here and have the following NOS parts for sale. Only have a few of some items.
Door weather seal 7375407 $5 ea
Diff. gaskets 7411818 4 for $5
Starter drive unit $10
Tail pipe extension/tip $10
Winch "U" joints $50 pair
Set of 6 window glass weather seal retainers, 2 long 4 short $25 set
Bed fuel pick up cover $10
Pinion seal (rubber) $6
Outer real axle bearing seal $6
Headlight trim ring $10
Exhaust pipe gaskets 5 for $3
Gas pedal $8
Brake shoe return spring $4
Dist points cam 7374879 $10
Window crank handle 7374797 $10
Carb gasket set. gaskets only no hard parts $10
Winch PTO with handle (used) $250
Plus shipping
Autodoc51@aol.com
Stuff For Sale
