Brass bushings for transfer case levers
- m37jarhead
I've taken apart the transfer case levers and see that the brass bushings are worn pretty thin. Anyone have a source for replacement bushings?
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
Past Pres
Member: MVPA #26600
Member: NRA
- HingsingM37
Quickest most painless thing to do is get a Bunting or Isostatic bronze bushing from any Bearing Distributor or McMaster Carr. For this app. you can use the sintered bronze (oilite) as they are less money. I don't recall the size I used on mine.
- m37jarhead
